Displays the number of Layer 4 port ranges consumed by the ACLs on the slices that support a particular port.
| port | Specifies to display the usage for the slices that support this port. |
N/A.
ExtremeSwitching series switches can support a total of 16 Layer4 port ranges among the slices that support each group of 24 ports.
Use this command to display how many of these Layer4 ranges are currently consumed by the ACLs on the slices that support a particular port. The output of this command also displays which ports share the same slices as the specified port.
The following example displays the Layer4 range usage on port 9:1:
Switch.3 # show access-list usage acl-range port 9:1 Ports 9:1-9:12, 9:25-9:36 L4 Port Ranges: Used: 4 Available: 12
This command was first available in ExtremeXOS 11.5.
